Discussion topic: No wifi
Message posted on 02 Nov 2025 12:44 PM
							No wifi
Message posted on 02 Nov 2025 01:08 PM
							Re: No wifi
Try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
Message posted on 02 Nov 2025 01:11 PM
							Re: No wifi
Been trying from last month but no luck. My TV is on the same floor as the hub but still no signals,poor signals or no keep loosing in the middle. So need to find out how to ask for booster or how to report to customer service but no help. Very disappointing
							Re: No wifi
Try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Message posted on 02 Nov 2025 01:25 PM
							Re: No wifi
We've had the same issue for past month , really disheartening to pay money for something that doesn't work very well, we are in a very small 2 bed flat and can't get connection in the same room as router
Message posted on 02 Nov 2025 03:12 PM
							Re: No wifi
@Chloe268 What issue is it that you have, maybe the Forum can help point you, can you say which sky Hub you are using and the package from sky for Broadband!
