Discussion topic: No wifi
This message was authored by: Jo+wrighttwins
No wifi
Orange middle light on routa
Re: No wifi
@Jo+wrighttwins
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
This message was authored by: AlexHunt
Re: No wifi
We've got the same. The internet light is off on the hub and socket also has a red light, we can't figure out how to get it back on, we've tried restarting and taking cables out and putting them back in
Re: No wifi
@AlexHunt The Red light is it a PON or a LOS? Forget about the hub that is the important one!
