Discussion topic: No wifi
Message posted on 15 Oct 2025 07:50 PM
No wifi
No wifi again 3rd time in a few days. No lights on the black box this time. I cannot do any work or watch tv or anything. I pay so much money for this & it keeps not working!
Message posted on 15 Oct 2025 07:51 PM
Re: No wifi
@NikkiEas
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
