1
This discussion topic has been answered Discussion topic: No wifi
This message was authored by: Magnetik
No wifi
No WiFi , internet connection down tried everything
Re: No wifi
@Magnetik
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
Re: No wifi
@Magnetik
