2
This discussion topic has been answered Discussion topic: No wifi
This message was authored by: Mr.+K.+Scott
No wifi
WiFi green light will not come on
Re: No wifi
@Mr.+K.+Scott
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your devices and your hub. Broadband is the actual internet connection provided by your ISP (Sky).
If your broadband isn’t working use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
Re: No wifi
@Mr.+K.+Scott
Avatar for Mr.+K.+Scott
Re: No wifi
Many thanks. I pressed the WiFi button and reconnected from sky settings on the TV
