Discussion topic: No wifi
Message posted on 02 Sep 2025 06:08 PM
No wifi
Message posted on 02 Sep 2025 06:37 PM
Re: No wifi
@Firth-c
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your devices and your hub. Broadband is the actual internet connection provided by your ISP (Sky).
If your broadband isn’t working use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
