Discussion topic: No wifi
This message was authored by: Ggreen39
No wifi
For 4 days my WiFi has been glitching constantly cutting off, orange lights displayed on the hub but yet when WiFi is checked says its all good. Engineer is needed to come look at my wifi
Re: No wifi
@Ggreen39
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
