Discussion topic: No wifi
This message was authored by: Rube
No wifi
Hi my broad band is not working can you help
Re: No wifi
@Rube
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
Re: No wifi
@Rube
The first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them.
