Discussion topic: No wifi
This message was authored by: Mc661
No wifi
Q mini not working, turned WiFi on off now won't come back on
Avatar for Mc661
Level 0 icon
No wifi
No wifi, can't contact anyone.
Re: No wifi
@Mc661
Is that because your Sky Talk landline is down too?
Wi-Fi is basically the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
