Discussion topic: No wifi
This message was authored by: RFeh
No wifi
Wifi has gone off, been going on and off all day now gone off and been off for 10mins
Re: No wifi
@RFeh
Wi-Fi is basically the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
