Discussion topic: No wifi
This message was authored by: Butch5
No wifi
Everything says my hub and WiFi connection are working but they are not
Re: No wifi
@Butch5
At that time of night it could be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If it hasn't returned by 0700 use this link to check to see if there are any broadband problems or outages nearby.
