Discussion topic: No wifi
This message was authored by: Dbwatson
No wifi
WiFi has gone down and I'm trying to work on my business
Re: No wifi
@Dbwatson
Wi-Fi is the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
