Discussion topic: No wifi
This message was authored by: Robert2112
No wifi
I have no WiFi though the sky check says that everything is ok
Re: No wifi
@Robert2112
Wi-Fi is the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
