Discussion topic: No wifi
Message posted on 05 May 2025 07:45 PM
No wifi
Our WiFi has dropped and cannot get it restarted
Message posted on 05 May 2025 07:48 PM
Re: No wifi
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
Message posted on 05 May 2025 07:50 PM
Re: No wifi
Thanks it comes up with we are having problems at the moment trya again later
does that mean in my area or everywhere
Message posted on 05 May 2025 07:52 PM - last edited: 05 May 2025 07:56 PM
Re: No wifi
@Daniel0210 Both the test's are down just now with the current Sky Fault, so it's a wait until they get past the current issue that they have.
Tested from the Scottish region...
Message posted on 05 May 2025 07:53 PM
Re: No wifi
Sky we're having some technical issues earlier.
Message posted on 05 May 2025 07:56 PM
Re: No wifi
Does that mean it may just come back up?
Message posted on 05 May 2025 07:58 PM
Re: No wifi
We're referring to the tests being affected by the technical difficulties not necessarily the broadband.
