Discussion topic: No wifi
This message was authored by: DC57
No wifi
I have no wifi again
Re: No wifi
@DC57
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
