Discussion topic: No wifi
Message posted on 10 Apr 2025 10:50 AM
No wifi
No wifi. Restarted twice but still no WiFi
Message posted on 10 Apr 2025 11:23 AM
Re: No wifi
@Yolandi1
Wi-Fi is the connection between devices and your router. Broadband is the internet connection provided by your ISP to your dwelling.
