Discussion topic: No wifi
This message was authored by: Jen25
No wifi
Wifi is not working ...only 2 green lights. I have tried resetting it and unplugging it but its not working.
According to the broadband check on the My Sky App all is ok.
Re: No wifi
@Jen25
In addition~
▪️This link providers information about the coloured lights on the various hubs
▪️ For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
