Discussion topic: No wifi
This message was authored by: MSB1
No wifi
Loss of WiFi connection
Re: No wifi
@MSB1
In addition~
▪️This link providers information about the coloured lights on the various hubs
▪️ For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
