Discussion topic: No wifi
This message was authored by: Laura2411
No wifi
Had power cut on 25th January and have had no wifi since then
Re: No wifi
@Laura2411
I have moved your post to the more appropriate Broadband board.
Any engineer visit that’s required is likely to be delayed due to the disruption from the recent storms.
