Discussion topic: No wifi - weak connection
This message was authored by: Mrye
Message posted on 02 Aug 2026 09:20 PM
We have a very weak wifi connection
Find out more
Message posted on 02 Aug 2026 09:34 PM
Re: No wifi - weak connection
A poor signal in certain rooms is something that can cause this so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
Alternatives are homeplugs or your own mesh network.
