Discussion topic: No wifi signal
This message was authored by: debsiecaroline21
No wifi signal
The WiFi has dropped but I've checked all connections and they are fine.
Re: No wifi signal
@debsiecaroline21 Just the wifi connection, the broadband internet is up working fine as far as you are aware?
This message was authored by: Jimg
Re: No wifi signal
Yeah, I think my sky router is not broadcasting. Our devices cannot see the router at all.
Rebooted all devices.
Re: No wifi signal
@Jimg Are you the same poster as @debsiecaroline21 or someone else?
This message was authored by: Rob_c201
Re: No wifi signal
I've had same issue all day
Re: No wifi signal
@Rob_c201 If your sky Hub is not broadcasting it's wireless name it's powered up then treat it as a faulty unit and call sky 8am to 8pm tomorrow and see if a replacement can be ordered, just dial 150 if you have a working landline or a sky mobile!
