Discussion topic: No wifi connection-Sky Glass
This message was authored by: KimiCM
Been having issues all day. Checked status online and apparently no faults. However, network check on tv says no Internet.
Re: No wifi connection-Sky Glass
@KimiCM
Are you other devices like phones connected to your Wifi and are working, if they are not the first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them.
Avatar for KimiCM
 No, no devices are connected to WiFi.
What was the results of the tests you ran ?
Avatar for KimiCM
Initially was saying that the broadband was connected but wifi wasn't. Have been keeping an eye on the service check and it's been updated to show a system outage in the area which 'normally takes a few days to fix' 🤬
Thanks for your responses 👍
Two working days is the usual time for Openreach to fix external issues but this doesn't include Saturdays and Sundays and also depends on where the issue is.
@KimiCM You know where to look now, and time scale is whatever it takes to do the fix.
