2
This discussion topic has been answered Discussion topic: No wifi again
This message was authored by: leigh41
No wifi again
This has to be the 8th time I have droooed out of internet again. 2 orange lights and all green when I check the WiFi on my phone. I have resent the hub twice but still no internet.
would someone contact me please to get this fixed
Re: No wifi again
@leigh41
If you’re not already aware this is a customer helps customer forum and you aren’t contacting Sky Customer Services on here. Sky won't contact you. They won't know who you are from a forum post which isn't linked to your broadband subscription.
The lines may be busier due to the damage and disruption caused by Storm Éowyn which will also impact an Openreach visit.
Re: No wifi again
@leigh41
Avatar for leigh41
Re: No wifi again
Thankyou
 I have spoken to sky, problem still not solved working on it.
