Discussion topic: No wi fi
Message posted on 16 Dec 2025 08:57 PM
No wi fi
Message posted on 16 Dec 2025 08:58 PM
Re: No wi fi
@Richie1968
The first thing to try (even if you’ve already tried it) is to use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
