Discussion topic: No wi fi
This message was authored by: NevS62
No wi fi
Router not working properly middle light flashing orange
Re: No wi fi
@NevS62
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
