Discussion topic: No wi fi
Message posted on 07 Nov 2025 07:39 AM
No wi fi
Message posted on 07 Nov 2025 07:59 AM
Re: No wi fi
@-Amanda-
Use this link to check to see if there are any broadband issues or outages nearby (even if you’ve already tried it ~ it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later).
