Discussion topic: No sky
Message posted on 17 May 2025 07:31 PM
No sky
Sky not working. Tried plugging out tried rebooting
Message posted on 17 May 2025 07:35 PM
Re: No sky
Presumably you're referring to broadband as that's where you've posted?
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
