Discussion topic: No signal
Message posted on 20 Dec 2025 08:59 AM
No signal
Red light on my router and no WiFi. Done a check on the app says all looks good, but it doesn't. I have no signal
Message posted on 20 Dec 2025 10:35 AM
Re: No signal
@Ang9
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
