Discussion topic: No signal
This message was authored by Hendy65 This message was authored by: Hendy65
No signal
Open reach socket flashing red on LOS?
Re: No signal
@Hendy65  Do you have a means to report this to Sky?
Re: No signal
@Hendy65
Thats loss of signal
You will need to call sky
Contact sky as below
Follow the link and choose need more help
https://www.sky.com/help/home/
If in the Republic of Ireland go to the bottom of the page and change the flag to Republic of Ireland
Hendy65
Re: No signal
Tried all that , turning it off, checking cables and it sends me back to test signal again? The openreach wall socket is flashing red on LOS (loss of signal) so its obviously an external problem ?
Re: No signal
@Hendy65  This is an external problem. Do you have a means to report this to Sky?
