Discussion topic: No optical network terminal
This message was authored by: Abbby
An engineer put a box on the outside of my house but I have no optical network terminal inside so have nowhere to plug in Ethernet cable? What is going on?
Re: No optical network terminal
@Abbby you should have an appointment for an engineer to come, they will run a cble from the exterior box into your home, fit the ONT and commission the service. If Sky haven't given a date then givecthem a call.
