Discussion topic: No nroadband
Message posted on 24 Jul 2026 05:45 AM
No nroadband
Message posted on 24 Jul 2026 06:54 AM
Re: No nroadband
@Sarahkatie1982
When there are broadband issues between midnight and 7am it could be essential overnight maintenance taking place. It is carried out at those times to minimise disruption and there is no advance warning provided.
See this pinned post at the top of the Broadband board from Sky which could be relevant any night this happens…
https://helpforum.sky.com/t5/Broadband/Important-Notice-Scheduled-Broadband-Maintenance/td-p/5151847...
If you have an ONT box displaying a red light, see this further advice…
This link provides information about the coloured lights you may see on the various hubs
Hopefully it’s back up and running before 7am. If it’s not, try restarting your hub or post back in this thread and we can try to offer additional advice.
Message posted on 24 Jul 2026 06:56 AM
Re: No nroadband
@Sarahkatie1982 wrote:
No broadband again
We're only other customers here, like yourself, so we'd need a little bit more information in order to help.
Firstly, unplug the hub for 10 minutes and then reboot.
Have a look at the following to see if they can resolve your problem easily if no success with the above, you can also use the MySky app.
To check on local outages.
To run the local checker.
https://www.sky.com/help/articles/broadband-diagnostic-start (do run all tests)
Not a Sky employee
Sky FTTP 500Mb to Max Hub
