Discussion topic: No network connection
This message was authored by: Jackiehouse
Message posted on 11 May 2026 08:03 PM
Saying on my tv that i have no network connection tried to network set up press wps nothing working cant get on my apps router box showing all green lights
Find out more
Message posted on 11 May 2026 08:26 PM
Re: No network connection
So after holding down the WPS button for a few seconds you then did the same with the same button on your broadband hub, if you did and it wouldn't connect then try getting your TV to search for all Wifi networks then connect to it with the password printed on your wifi hub.
