Discussion topic: No network connection
This message was authored by: Sharon4579
I have tried to fix the problem by network set up and it won't connect however when I checked the  app it states that all is fine. What else can I do please
Re: No network connection
@Sharon4579 Is the hub showing you that see the link below.
This link below provides information about the coloured lights on the various hubs that can help to see what is going on! If the system is also Full Fibre then the lights on the OR/CF ONT also require to be looked at!
and if possible the second one below this!
If you haven’t done it already use the below link to check to see if there are any broadband problems or outages nearby if enough time has passed for a fault condition to be displayed by the software test! This should determine if there's an identified fault affecting multiple households.
