Discussion topic: No lights on modem
This message was authored by: Garrytrevor
Message posted on 21 Jun 2026 05:15 PM
No lights on modem
No light at all on nt fibre modem
Find out more
Message posted on 21 Jun 2026 05:16 PM
Re: No lights on modem
If none of the lights are lit and it is the same if you connect it to a different power socket then give Sky a call as it might have died so if that is the case you would need a replacement.
