Discussion topic: No lights on hub
This message was authored by: Vicki851
Message posted on 08 Jun 2026 06:55 AM
No lights on hub
Hub has no lights on all connected as should be just suddenly went off.
sky saying everything is ok but the hub isn't swithing on?
Find out more
Message posted on 08 Jun 2026 07:55 AM
Re: No lights on hub
No lights at all would indicate a power supply failure. If the Hub doesn't light up on a different socket then you'll need to log it with Sky as a complete failure are wait for a replacement to arrive.
