2
This discussion topic has been answered Discussion topic: No light on router
This message was authored by: Luna101
No light on router
No internet connection router has no light at all
This message was authored by: JimM1 Answer
Re: No light on router
@Luna101 What sky hub are you using, if All the lights are out or the Single light is out, check the power source is working first, after that it;s a call to sky for a replacement Hub, see the ones linked below!
This link below provides information about the coloured lights on the various hubs that can help to see what is going on! If the system is also Full Fibre then the lights on the OR/CF ONT also require to be looked at!
Avatar for Luna101
Thank you.  Power source is working so must be needing a new hub 🙄. Thank you for advice
