Discussion topic: No iternet
This message was authored by: jeays67
No iternet
My Internet connection has gone and tried turning box on and off and the reset button
Re: No iternet
@jeays67
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
