Discussion topic: No internet or calls
Message posted on 21 Jul 2025 12:22 PM
My internet suddenly stopped working and unable to make receive calls on landline deserted box but still the same issue
Message posted on 21 Jul 2025 12:25 PM
Re: No internet or calls
Not sure what you mean by deserted box.
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
