Discussion topic: No internet light on hub
This message was authored by: Ash971
My internet has been cutting off and on intermittantly throughout the day, and now after resetting the router, the internet light on the hub isn't lit, and stays unlit after resetting the router and the ONT box
Re: No internet light on hub
@Ash971
See further down for guidance on the lights on the various hubs.
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
▪️I AM NOT A SKY EMPLOYEE ▪️
