Discussion topic: No internet ive checked my connection already
Message posted on 01 Sep 2026 04:36 PM
My Internet has gone off and it not come back on ive reset the box checked connection but its saying its good but I have no Internet at all
Message posted on 01 Sep 2026 04:44 PM
Re: No internet ive checked my connection already
@Cherrellehgh
Start by using this link to check if there are any broadband issues locally that may identify a known fault which could be affecting multiple households ~
(this won’t necessarily identify a fault just affecting your address).
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
