Discussion topic: No internet for 3 days
This message was authored by Dumitru This message was authored by: Dumitru
Hello, my internet has been down for 3 days, I have checked status and everything is fine. I am not sure why it is down. I am also trying to contact sky via phone but i cannot find no phone number that works, it says "the phone number doesn't match your account number" I am not sure what this means. Any help would be appreciated.
This message was authored by Daniel0210 This message was authored by: Daniel0210
Re: No internet for 3 days
@Dumitru
If you definitely need to contact Sky then if you already have a Sky Mobile or a Sky Talk landline call free by dialling 150, otherwise you can use:
https://www.sky.com/help/home
UK customers: Scroll down and click on ‘Need more help’ and it provides a 0333 number.
ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ and it provides a 0818 number.
(The forum doesn’t allow us to type the numbers in full).
You will find that similar to calling other large companies the start will be automated which may also try to send you back to the forum. Be aware we’ve been informed the lines are busier than usual at the moment.
This link explains auto compensation for when there is a TOTAL loss of Sky Broadband or Sky Talk.
https://www.sky.com/help/articles/auto-compensation
If you have a total loss of service and it isn’t fixed after two full WORKING days from when you first report the fault to Sky, you will become eligible for it. It’s applied 30 days after the fault has been repaired and will come in the form of a credit appearing on your account.
▪️ I AM NOT A SKY EMPLOYEE (undercover or otherwise) ▪️
