Discussion topic: No internet connection
Message posted on 23 Aug 2026 06:50 PM
My sky app is saying everything looks good but we have no internet WiFi in our home
Message posted on 23 Aug 2026 07:04 PM
Re: No internet connection
@Georgia142
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
(this won’t necessarily identify a fault just affecting your address).
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
