Discussion topic: No internet connection
Message posted on 07 Jul 2026 10:55 AM
My internet has gone down and there is a red light for LOS on my ONI box. Power is green and LAN is flashing, the PON has no light whatsoever.
my Sky hub is has green for power and WiFi, orange for voice and nothing for internet.
I've tried turning the hub and ONI box off as suggested I've tried this twice but it's still the same.
what should I do now?
Message posted on 07 Jul 2026 10:57 AM
Re: No internet connection
@ZC2
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
