Discussion topic: No internet connection
This message was authored by: JakeR96
I have no internet connection, I have green lights on power and WiFi but flashing amber on internet and no light on voice, I have tried resetting and also tried unplugging for ABIT then plugging back in but still no connection
Re: No internet connection
@JakeR96
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
