Discussion topic: No internet connection
This message was authored by: Jpaintain
This message was authored by: vomitself77
Re: No internet connection
yup. same here. probably a software update.
@Jpaintain
Even if you’ve already tried it the first thing to do is use this link to check if there are any broadband outages or issues locally that may identify a known fault, perhaps affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst it's fine for customers working from home to use it, they won’t receive additional or quicker support.
