1
This discussion topic has been answered Discussion topic: No internet connection
This message was authored by: Mkjacobs1000
I don't have internet connection or WiFi
Re: No internet connection
@Mkjacobs1000
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
If you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
@Mkjacobs1000
