Discussion topic: No internet connection
Message posted on 23 Apr 2026 07:06 AM
Hi we have no internet connection all lights are on the router but it isn't working and neither is the tv
Message posted on 23 Apr 2026 07:10 AM
Re: No internet connection
If you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
