Discussion topic: No internet connection
This message was authored by: Banus82
This message was authored by: Steveggow
Re: No internet connection
I have the same problem. Most nights my services goes down it's eithet seconds or minutes. And always when Im watching something
@Banus82 @Steveggow
This message was authored by: Isa7
No internet connection all the time is drop
Isa
My internet dropped and not connected yet I turn off everything and nothing works long time
Re: Isa
@Isa7
Try running this line test to see if it finds any faults:
