Discussion topic: No internet connection
Message posted on 02 Jan 2026 03:50 PM
Checked all connections but wi-fi and internet not connected
Message posted on 02 Jan 2026 04:05 PM
Re: No internet connection
@Jen169
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
