Discussion topic: No internet connection
This message was authored by: Barrie15
Amber light on router. Had intermittent problems last few days.
Re: No internet connection
@Barrie15
The first thing to try (even if you’ve already tried it) is to use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
This message was authored by: Steve1875
Ive had no Internet for a week now I keep phoning but first it was an external issue now your saying its internal
@Steve1875
No, we aren't. You aren’t contacting Sky here. This is a customer ▶️ customer discussion forum where we try to help other customers.
